Are these nasty plugs my problem???
Old Aug 27, 2002 | 12:02 PM
lopoetve's Avatar
Ok. I've had some issues with my TPI 305 (87 Formie) idling cold. It surges, sputters, occasionally has detonation, and lacks power. Once it gets to 120*, all is good and it ran like a dream.
Then I failed emissions. 7/3 on HC. 3.4/3 with guaranteed to pass.
Anyway, I had a sinking feeling on the plugs, so I pulled them. The previous owner replaced them a year or so ago, so I figured they were "ok".
They were Splitfires, with a .070 gap (I'm supposed to have .035).
Are they most likely the source of all my problems?
Old Aug 27, 2002 | 01:24 PM
rezinn's Avatar
Yes! Buy some a/c delcos and gap them to .035 and try again.
Old Aug 28, 2002 | 02:47 PM
lopoetve's Avatar
4 replaced, runs smoother and can start one one try now
But I can't get the wire off of 5 or 6, and 7&8 are a royal PITA.
Any tips?
Old Aug 28, 2002 | 06:55 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
try gettin them out from underneath the car, as for the wires you could always buy one of those plug boot removers or whatever they're called
Old Aug 28, 2002 | 08:04 PM
rezinn's Avatar
Definitely get underneath the car. Wear some goggles if your engine is dirty or has ever been on fire
Old Aug 28, 2002 | 08:07 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
[edit:] my below splitfire statement is not necessarily the same view that Honeywell (who makes them) has about them (company policy hehe)
yeah i hear splitfires are money down the drain, best plugs to use are finewire double platinum, if they make it for your application. they require less voltage to create spark
Infested
May 22, 2018 11:56 PM
Bert87
Aug 23, 2015 03:50 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
