'89 2.8 V6
Old Aug 28, 2002 | 09:23 AM
Shorty Cox's Avatar
'89 2.8 V6
Not sure I'm in the right place to ask this question. I'm installing a '89 2.8 V6 into my sandrail. I will be using a aftermarket high pressure in-line fuel pump for the injectors. My question is, Will in need an in-line fuel regualtor or does the engine have a built in regulator?
Any help is appreciated.
Shorty
Old Aug 28, 2002 | 10:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The engine should include what it needs; that is, the regulator is nomrally mounted on, and controlled by, the engine. As long as your pump can supply about 45 psi to the engine you should be OK. You will need a return line from the engine (regulator) back to the tank in addition to the usual supply line.
Old Aug 28, 2002 | 11:15 AM
Shorty Cox's Avatar
Thanks,,that is what i wanted to hear. This has been one heck of a project.
Shorty
86maro_252
Oct 10, 2015 06:52 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
89bird2.8
Sep 18, 2015 07:46 PM
