Battery Size
Battery Size
What size batteries (CCA) are you guys using on your 350's? I have an 83 Z28 that I did a 305 - 350 swap and I am suspecting that my 630 CCA battery is giving me starting issues,slow cranking ect., before I start testing all of the obvious, I would like to know if my battery is too small, after all it is an easy fix!
Car: 4
Engine: 6
Transmission: 5
It's the starter. Don't waste your money on batteries, go straight to the problem.
Get a "mini-starter", it makes an incredible difference. I went through the same thing with a 400 in my car. I got the CVR unit, it spins the motor about 3 times faster than the stock one ever did.
Car: 4
Engine: 6
Transmission: 5
I got it at my local shop when i lived in Memphis... Can't recall the number, it's the CVR that has the 4 bolts, for both ring gear sizes... i had it on my 400 first, I had drilled the 400 block of course since the 153-tooth starter won't bolt to the pattern that comes on those; with that motor, the best the stock starter could do with any battery was just barely budge it, if it didn't start within about 5 seconds of the time i hit the key, the battery was toast; with this starter, it's like it has about 4 times the power and draws about 1/4 the power off the battery.
Thanks again, you were right, it was the starter, I looked for what you recommended locally and came up short, so I tried a heavy duty mini-type starter from Napa and it spins it over like a dream. Thanks again
Linson
Sep 21, 2015 01:08 PM
