406 will it fit without problems??
Old Aug 30, 2002 | 05:02 PM
quick_90's Avatar
i was thinking about putting a 406 in my 1990 but dont know if it will fit or not. i know with alot of cash i could do it easly, but guess what i dont have alot so i was wondering if its possible and if there are any big problems that i will run into if i tackle this job?
thanx
Old Aug 30, 2002 | 05:16 PM
Hulk0202's Avatar
The 400 is a small block like the rest and will fit with no problems. You will need to get the right motor mounts. The flywheel and starter will have to be for a 400 i believe. But clearance wont be a problem.
Old Aug 30, 2002 | 08:35 PM
Polecat's Avatar
Starter will be the same...all SBC engine mounts are the same...exhaust is the same...just need a 400 flywheel.
Old Aug 30, 2002 | 09:42 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
well.. technically,, the starter is not interchangable with all 350s/305s
400s do not have parallel bolt holes to mount mini starters. When you have the block machined get it drilled for a mini starter (some minis have offset bolt holes now).
You also need a harmonic balancer that is externally balanced. And there are the issues of connecting rods.
The motors are externally the same.. but some special circumstances exist that must be considered
Old Aug 31, 2002 | 10:44 AM
JOHN/88IROCZ's Avatar
If the 406 is a BB it is going to be tight. One of my buddies put a 396 in his '87 no emmissions,heater or A/C and it was still pretty tight.
Old Aug 31, 2002 | 02:35 PM
quick_90's Avatar
ok the block im might be buying has everything on it and came out of a stock car, has nyone done this swap, cause i thought that a 400 block was just a little bigger than a 350?
anyways thanx for the replys
Old Aug 31, 2002 | 04:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
no, a 400 block is externally the same size as any other small blcok chevy. As was already said, the only issues are the flywheel which will probably need to be "unbalanced"; the fact that all 400 blocks have only the driver's side oil dipstick in the deck surface of the block which will not work with late model exhaust manifolds; they pre-date the invention of the 12-3/4" flywheel, and so are missing a starter bolt hole required for that; and the balancers that are available have the 1:30 timing mark instead of the 12:00 one that these cars' accessory setup requires. none of these are insurmountable. I drove my 83 around for about 11 or 12 years with a 400 in it, and it will be going back in soon.
Street Lethal
Apr 30, 2019 12:14 PM
Regal105
Aug 23, 2015 03:45 PM
theurge
Aug 21, 2015 12:46 PM
TheJoeY88
Aug 13, 2015 06:51 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
