want to trash the 882 heads, but what to go with?
Old Aug 30, 2002 | 11:54 PM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
i finally installed my roller rockers last night and i noticed that i have the garbage 882 casting heads on there. I want to get rid of these pretty much immediatly, because they are about the last choke point on my motor. The question is what to go with as replacements. I don't really want to go with an iron head like a vortec or iron eagle. I also cannot afford a set of AFRs. That being said, i'm looking at a set of trickflows, but am in a toss up between the regular 23* heads, and the G2 twisted wedge heads. Being that there both about the same price, which would give me more power? I'm not against go with something different than those two if they cost about the same, and will yield better gains. One thing though, i would like them to work with the rockers i just bought, and they need to be assembled. Sooo... heres the engine combo:
9.5:1 compression stock bottom end
272H crane cam (.454 lift with 1.5r, .484 with 1.6r, 218* dur, 112 lobe sep)
Summit stamped roller tip rockers (1.6)
Edelbrock performer intake
non cc qjet and HEI dist.
Edelbrock TES headers, and catback with hi flo cat
t-5 tranny
3.42 gears
any thoughts and opinions are more than welcomed...
Eric
Old Aug 31, 2002 | 07:37 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
With that cam I would go with the pro lightning aluminum 180's. There is a shop by me that sells them for $940 but they are like $1100 from summit. These are supposed to be nicer castings than trick flows.
Old Aug 31, 2002 | 09:51 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
you know i've heard abut these, is there a website for these guys? I may have to look into those...
any other suggestions?
Eric
EDIT: just checked out the specs in Summit, and that seems like way to much for my application. They talk about spinning at like 7500-8000 rpm. Lets not forget that my cam only has 218* dur. I don't really want or need to take this motor past 6K.
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
92projectcamaro
Jan 18, 2016 08:00 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
