code 36
Old Aug 31, 2002 | 05:36 PM
BadMunky87TA's Avatar
code 36
i got a code 36, so i replaced the burn off relay, and it went away for a day, but now it is back, what else should i check?
Old Aug 31, 2002 | 05:55 PM
nm, that search button is cool
Old Aug 31, 2002 | 06:34 PM
ok, i checked the 2 orange wires for power but they are dead, how do i "repair open ciruct"
Old Sep 27, 2002 | 02:42 PM
chev-hell's Avatar
dude, just just did a search because i have the EXACT same simpton on my 89.... can't figure it out.........
Old Sep 28, 2002 | 07:19 AM
Vader's Avatar
Munky,
Check the connection at the MAF itself. The connection there is critical. You should also check the MAF power relay. Inspect the connections at both the MAF power and burnoff relay sockets. The burnoff circuit routes power to the MAF burn off terminal through the normally closed contacts of the MAF power relay.
Also check the operation of the auxilliary oil pressure switch, since that is what the ECM senses to initiate the burn off cycle. If you hear the fuel pump run for a long time after shutdown, that's a hint.
Let us know how that goes for you.
Incidentally, "Where the Hell is Neenah?"
Old Sep 29, 2002 | 02:40 AM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Just because nobody did in fact answer the open circuit question
It's any of the wiring/connection relating to the connection itself...
so there's either a poor/corroded connection somewhere, a damaged wire, a short etc....
Old Sep 29, 2002 | 04:24 PM
i took a test light to the 2 oranges at the burn off relay and didnt get anything from them so its off thru the wonderful world of wires and grease
at the burn off relay connector the wires are showing a good 1/2-1/4 in of fully stripped wire so that is prolly where i should start
btw, neenah is in the same pile as menasha :lala:
Old Sep 29, 2002 | 09:44 PM
Vader's Avatar
Originally posted by BadMunky87TA
btw, neenah is in the same pile and menasha,:lala:
Yes, as is Appleton, Omro, Winnecone, etc. I used to be in O-Town, on the west edge of the lake. How do you think I cam to have such a craving for lake perch (and Leon's)?
Old Oct 1, 2002 | 06:01 PM
hehe, i used to live in O-town, on algoma, 20-30 feet from the dorms :P
Leons rocks
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
