Best TC and rockers for the lil 305
Old Sep 4, 2002 | 05:23 PM
Matt86t/a's Avatar
Alright guys, what are the best torque converter/stall and rocker arms for my car? I got the little 305 and i'm sticking to it. No need to convince me in getting a 350. 10 yrs from now a 305 will seem even cooler to be running 14's (i hope by then) . I'd like about the same gas mileage too. I was thinking comp cams 1.6 rockers. I saw them in Summit for $191.95. Sound good? Also i was thinking of getting one of the B&M Tork Master converters. The 2400 sounds pretty good, but it has a 2,300-2,500rpm stall. I think that may be too much. The 2000 has a 1,900-2,100rpm stall. I'll get the one with the appropriate stall. It's only like $30 more for the 2400. Anyone have any of these mods? Thanks a lot for your help guys.
~Matt
Old Sep 4, 2002 | 07:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I haven't heard enough good things about B&M lately to risk one of their converters. Talk to Dana at Pro Built, he'll get you on the right track.
The cam and torque converter are a matched set - you need the TC to work well with the cam you have. And, 1.6 rockers are typically a "cheap" way to increase lift without having to get a different cam. In your case, the cam is so mild that it probably wouldn't make a noticeable difference.
A 305 running 14's? Not too big of a deal, really. Mine has 150k miles on the shortblock and tranny, ran the best time listed in the sig last Saturday (8800' equivilent altitude - the correction only takes elevation into account). I drove it to the track in the morning because I left the '57 there overnight; decided to give the Camaro a try, so emptied the trunk, adjusted tire pressures, disconnected the thermovac on the air cleaner, and disconnected the AC so I could use the fan to help cool it down. First run out produced that time.
Old Sep 4, 2002 | 07:39 PM
Matt86t/a's Avatar
thanks. What TC would go with my cam, and what kind do you have? What would be a good stall speed? Right now it's the stock 1,500rpms. I wouldn't think i'd need to go much higher.
~Matt
Reborn756
Sep 4, 2015 03:42 AM
3.8TransAM
Sep 3, 2015 06:38 PM
Thaney9
Aug 29, 2015 03:16 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
