big problem starting car...help please
Old Sep 5, 2002 | 03:24 PM
IceBlue91z28's Avatar
Car: 1991 Camaro Z28
Transmission: Built 700r4
OK here is the deal. It is a 91 z28 with the vats key. I have two keys...the origional and the copy. Each works(sometimes). WEhen I first baught this car it would start but sometimes only click when I turned the key. A few weeks ago, I replaced the starter and the vats relay because It would only make a buzzing sound in the relay. Then it worked for like a week and now I am away at college and it wont start at all. The security light comes on then goes out after 2 seconds like it is supposed to so what could this be? Could the wires in the lock cylender be worn out or something. I dont know what it is. i can still sometimes get the car to makie the buzzing in the relay but I cant even get it to make the starter click anymore. Please help I need to get home this weekend for a car show. Thanks a lot.
Old Sep 5, 2002 | 03:39 PM
Kevin Johnson's Avatar
Are you sure your battery is okay?
Old Sep 5, 2002 | 04:59 PM
yah the battery is fine i tried to jump it but it didnt do anything and all my lights and radiop work but i think it might be the key lock cylender
Old Sep 17, 2002 | 11:50 AM
91-GasGuzlinZ-28's Avatar
I'Ve got the exact problem with same system. I hear the fuel pump when i go to turn the key, but nothing happens. My voltager, temp go up. Security light goes on but no start. What could it be and how do i fix this problem?
Old Sep 17, 2002 | 04:58 PM
the problem was that i had an alarm and it was malfunctoning and i took it to a mechanic because theres really nothing you can do.
Old Sep 17, 2002 | 05:17 PM
Firl's Avatar
First thing i had to do to my car to make it start was take out the car alarm
Old Sep 17, 2002 | 06:06 PM
You both mean an alarm system besides VATS, right?
Old Sep 17, 2002 | 07:08 PM
Firl's Avatar
.... vats? ... i think alarm system
Old Sep 17, 2002 | 07:45 PM
yah an alarm besides the vats
Old Sep 18, 2002 | 10:01 AM
If i just turn the alarm off by flipping the switch, will this be enough or do i have to take the whole alarm system out?
Old Sep 18, 2002 | 10:47 AM
mine he had to take the WHOLE system out because it is all tied into the vats and neutral saftey switch. Now is your security light inthe dash going off after 2 seconds?
Old Sep 18, 2002 | 10:48 AM
Before you go rip out your alarm take it to a professional you trust because that wiring is very complicated and if you do it yourself it might get messed up and u will never get your car to work. It might not even be the alarm it could be something like a loose wire but I know mine the alarm was messing it up.
Old Sep 18, 2002 | 11:13 AM
Vader's Avatar
Have you tried cleaning the VATS contacts in the ignition lock cylinder? It only takes a few minutes and may solve your problem completely.
Old Sep 18, 2002 | 06:46 PM
No the light remains on and so does the service engine soon light.
Old Sep 18, 2002 | 06:47 PM
How do you remove the ignition lock cylinder to clean it?
Old Sep 18, 2002 | 07:08 PM
well if the security light remains on it is not the alarm. It is your vats system so it could be your key, lock cylender, vats unit or something like that. dont take your alarm out because it isnt broken. It is you vats so either bypass it or get a new vats unit which i have no idea how to replace or how much it is.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
