Rochester Quadrajet
Old Sep 5, 2002 | 10:24 PM
81GMC's Avatar
Rochester Quadrajet
Does anyone know where to locate replacement seals for the throtle body plate of a stock Rochester Quadrajet. circa 84 Federal 305 engine without electronic controls other than an electric choke. Specifically the seals that go around the linkage rods that hold the throtle plates for the primary and secondary plates?
Old Sep 5, 2002 | 10:34 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
There arent any actual seals. If your throttle plate is worn out you'll need to have it re-bushed. Jet makes a kit that has bronze bushings and a reamer for doing this. It's kinda expensive though.. $80 when I bought mine.
Old Sep 6, 2002 | 10:30 AM
2vmodular's Avatar
Watch out, worn throttle plate bushings can cause the accelerator pedal to stick.
(it is difficult to safely drive a vehicle if the gas pedal is stuck to the floor and will not pop back up)
PurelyPMD
May 5, 2016 04:57 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
Scorched1984
Sep 15, 2015 03:42 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
