lt4 cam
Old Sep 9, 2002 | 03:36 PM
BigErns90IrocZ's Avatar
lt4 cam
Once I get my Camaro and get some basic mods done I am going to upgrade the cam. Few questions, will an lt4 cam work in an a 305 tpi like a lb9? If I got an l98, how much, an estimate, of how much it will cost to get cam and all necessary parts for cam.
Old Sep 9, 2002 | 03:41 PM
rezinn's Avatar
Do you mean the LT4 cam or the LT4 HOT cam? You can get the LT4 for $180 from a dealer, and then you're going to need gaskets and rtv, timing chain and gears is a good idea too. Altogether probably a little over $250 bucks. Maybe more if I'm forgetting something, but not a lot more. It's a good time to flush your coolant and change your oil too, so you could add that in. It's also a very good time to put some roller rockers in place of the stock stamped steel ones.
Old Sep 9, 2002 | 05:35 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
He's gonna need new springs.
Old Sep 9, 2002 | 07:36 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
lt4 and lt4 HOT cam are both roller, don't use them if your motor is flat tappet. a hot cam might be too much for a 305. i have a HOT cam in my vette l98 and it's great. was only $185 from scoggin dickey i think, i didnt have to get screwed in studs installed cuz the vette heads got them stock. i had my valve guides and the steel spring seats milled and got new springs
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
tommy z-28
Oct 6, 2015 10:58 PM
customblackbird
Oct 1, 2015 04:30 PM
masonta
Sep 1, 2015 06:40 PM
