oil pump
Old Sep 12, 2002 | 05:19 PM
holmes677's Avatar
oil pump
i recently bought a new oil pump for my 84 Z HO 305. How do i get the screen off the old one and on to the new one?
Old Sep 12, 2002 | 05:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The easiest way is to pay the $5 for a new screen. Part # 55-S
While you're at it, get a Mr Gasket pressure regulator spring for it, part # 26; that will take the pressure to 30-35 idling and 55-60 cruising. And, get an intermediate drive shaft for it that has a steel collar instead of that stupid plastic BS; part # IS-55-E.
Old Sep 12, 2002 | 06:15 PM
holmes677's Avatar
the pump i got is a high volume one, but is there anyway to take the screen off the old one?
Old Sep 12, 2002 | 06:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would recommend taking it back and getting a regular one. Just a plain, common, $12 M55. A high volume one won't do you any good, maybe even more harm than good. With the difference in price you can easily afford the other parts. And, you'll have a nice clean screen.
I never re-use the screen. I've re-used pumps and put new screens on them; I put the pump body in a vise and use a blunt chisel to knock them off.
Old Sep 16, 2002 | 11:27 PM
holmes677's Avatar
ok, i got the new oil screen from the store, but not, how do i get it in the new pump? Its like press-fit but hard as hell to barely get in. thanks for all your help.
Old Sep 17, 2002 | 12:25 AM
kevinc's Avatar
Car: 1982 Z28
I put the screen/pickup in the freezer for a few hours, then remove the pump's lower cover and bake it in the oven at 350degF for 15 minutes. The screen/pickup with then slide right into the pump's lower cover with minimal effort.
You'll need to reassemble the pump and set the pickup position to put it 3/8" off the oil pan's floor.
When it's set right, take it to a shop and have then spot-weld the pickup to the pump housing...after removing the lower cover (again) and removing the pressure relief spring and piston.
Yes, it's a lot of work, but absolutely worth it. The pickup won't come off, and it will be in the right position.
Old Sep 17, 2002 | 09:26 AM
ede's Avatar
ede
lot of people weld the pick up to the pump cover but i wouldn't. i weld a brace on the pick up tube and bolt it to the pump, using one of the pump cover screws.
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
