Tall valve covers on an 89 Iroc???
Old Sep 12, 2002 | 09:06 PM
bo ty guy's Avatar
Car: 92 Grey-Green B4C
Engine: mini-rammed 383
Transmission: Tremec TKO
How in the heck do you fit tall valve covers on my car? The alternator wire is directly in the way! I'm runnning TFS 23 degree heads if it makes a difference. Center bolt pattern valve covers. Thanks!
Chad
89 Iroc 406, TFS 23degree heads, vic junior intake, Holley 800 double pumper, SLP headers, a few other goodies, TKO 5 speed, moser 12 bolt with 3:73's
Old Sep 12, 2002 | 09:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Reroute the wire
Old Sep 12, 2002 | 09:56 PM
rezinn's Avatar
The alternator won't swing out of the way if you loosen it, and then swing back into position without touching the valve cover?
Old Sep 13, 2002 | 02:31 AM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Grind the one wire stud down as close to the threads as you can or carefully rotate the back on the alternator about 120 degrees counter-clockwise, (as you're looking at it from the back) by removing the three (I think) bolts that hold it together. Be careful and not pull the back on the alternator too far out when you do this! Then, the pluged in wires may be a little short but it still plugged in on mine. The one wire stud just did clear when I did this but it worked.
This is called re-clocking the alternator by some people and has no effect on the operation of it.
Old Sep 13, 2002 | 06:32 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
mine still would not clear after reclocking.
I used these VCs
http://www.gmpartsdirect.com/perform...CATID=777.html
Old Sep 13, 2002 | 11:19 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
i ground down the stud and i have just enough room to swing the alt.
but i can't remove my DS valve cover with out disconnecting the battery
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
g.l.mos
Aug 22, 2015 12:02 AM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
