Ideal bore to stroke ratio?
Old Sep 15, 2002 | 08:30 PM
worldofool's Avatar
Just wondering if there is a best bore to stroke ratio if so what is it. And also how do different rod lenghts change the stroke (how can i figure it out with different lenght rods like 5.7 or 6)
Thanx
Old Sep 15, 2002 | 09:48 PM
89WS-6's Avatar
this is a good question. And all I know, is that a chevy 350 has a 3.75 stroke, and uses 5.7 rods. Sorry.
Old Sep 15, 2002 | 10:08 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
the 350 has a 3.48" stroke
the 400 has a 3.75" stroke
the rod lengths do nothing for the stroke. all they do is change where the piston pin is. and somehow change something with TDC timing.
for the bore to stroke ratio......the 302 has the best, ie 4.00"x3.00"
but if you wanted to increase that....a 400 block with a 3" stroke would be rediculous.
Old Sep 15, 2002 | 10:33 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Just remember that a longer stroke will make a bit more torque, but it's also gonna increase piston speed so you probably won't wanna rev it as high as a standard stroke unless you have a bullet proof bottom end. Stroker motors can be hard on rods so they must be stout to rev high because the faster piston puts a lot of load on them during the exhaust stroke. And as far as the rods go, a longer rod will usually make a little more torque also, kinda like how you can apply more torque with a longer wrench then a shorter one.
Old Sep 15, 2002 | 11:45 PM
iroc22's Avatar
Generally, the mechanical efficiency in a racing engine, where higher crank speeds are not a problem, is better with a larger bore and smaller stroke. The short stroke results in less frictional loss since speed is considerably reduced. The breathing ability for a given cylinder displacement should be increased with a larger bore because there is simply more area across the bore in which to fit the larger valves. The shorter stroke will also allow relatively shorter rods and a shorter block deck height. All of this adds up to reduced engine weight. Of course, this is a complex technicaly consideration since it is possible to have the rod ratio too high for the displacement, resulting in induction feeding difficulties. This is a matter of balance and design skill.
Now stroke length versus performance is always a flame war. The common factory sbc lengths are: 3", 3.25", 3.48" and 3.75" (good luck tryin to find that 3.1" crank, they're still out there though ) In low speed engines (ex: street driven), there is some degree of performance gain with every increase in stroke, all the way through 3.75". There is not however, a linear increase in output (power per inch) as the stroke goes up. There maybe be more torque; and with considerable work, it is possible to attain a pretty good specific power curve up to a stroke of 3.48".
When maximum specific power is desired for racing purposes, other considerations enter the picture. In this instance, the stroke length must be dealt with in terms of the available rod length and piston design. These are important factors in the induction efficiency of the engine; after all, this is where the game is won or lost. In simplest terms, the reciprocating piston, internal combustion engine can be viewed as a pump. The better it draws in combustible gases, burns them, turns the crank and pumps them out, the more power it will produce (simple right?). Now considering those requirements, it is possible to gain a fairly decent rod length to stroke ratio at any stroke lengths between 3" and 3.48" (sorry 383 and 400 guys ). When the restrictions of piston design and induction system design enter the picture, the best compromise is the 3.25" stroke (of course any of the common strokes can produce suitable power curves if the overall engine is properly designed).
An engine with a stroke of 3" should have a relatively high specific power curve through a wide engine speed range. However, with a stock length 5.7" rod, the piston compression height is very tall. With all this room between the pin and the piston deck, the piston is very heavy. A longer rod would put the pin higher in the piston and save some weight. This is a slight secondary consideration and one of the possible advantages of longer strokes.
A stroke length of 3.25" provides an excellent compromise. The rod length can be nearly optimized without severly restricting the piston design. A 3.25" stroke has an optimized rod length of 5.9" (a 1.8:1 ratio). This rod is only slightly longer than the stock 5.7" rod.
With the 3.48" stroke, the piston design becomes a problem because of the high pin placement. Above this engine size/stroke length/rod length, the peak power curve falls off rapidly beyond 8000rpm (does anyone on this site have a 8000k 350?) A lot of circle track 350's are running 5.85" rods (1.7:1 ratio), but many Nascar 350's are using 6.0" rods. 5.7" rod engines don't have th same fuel specific curve as the short rod engines but are almost as good in output. The longer rod engines with smaller volume, 4bbl intakes seem to be more flexible and produce a broader torque peak, which would work quite well on the street.
So after my novel, I'd say the absolute optimum engine is the 327 with 5.9" because of the fuel specific curves you can create with it. On the other hand, I imagine most people who are interested in what they should run for bore/stroke are mainly driving their engines on the street and not building for 6000 plus rpms so they should not worry about bores and strokes; in which case:
There's no replacement for displacement.
Old Sep 16, 2002 | 06:28 PM
Christobal's Avatar
Good info
You may want to mention Grumpy Jenkins in your post somewhere.
" but many Nascar 350's are using 6.0" rods. 5.7" rod engines don't have the same fuel specific curve as the short rod engines but are almost as good in output."
You meant to say, fuel specific curve as the 'long rod' engines..... not the same meaning, they (shorter rods) have a less efficient brake specific fuel consumption curve.
Also many top NASCAR engines and probably many well below the top ranks, are running 6.0+ rod lengths, with strokes like 3.335 and 4.125 bores and rod to stroke length ratios in the 1.8 to 1.9 range.
Old Sep 17, 2002 | 12:14 AM
iroc22's Avatar
Yes I've been reading a lot of Smokey Yunick and Grumpy Jenkins stuff lately. As you probably noticed a lot of that info was pulled from Jenkins
Old Sep 17, 2002 | 05:40 PM
1PTR315's Avatar
Smokey always said "stick the longest damb rod in it you can fit"
The longer the rod, the more dwell time at tdc and the faster the piston moves at mid bore. This has an advantage of helping the engine be less detonation sensitive because the extra dwell time lets the engine "think" it has more timing. You can sometimes get more compression in the thing that way. Only bigger lift cams can take advantage of the extra piston speed down the bore. Long rod also make cam timing at intake closing much more sensitive. The extra piston speed does help torque though because at 90 degrees the piston is also easier to move down with a longer rod.
Old Sep 17, 2002 | 10:28 PM
RICHRAD's Avatar
It's amazing that there is only a .270 difference in those strokes. Don't see how so little could make extra torque. Or be harder on the rods for that matter
InfernalVortex
Apr 20, 2021 11:31 AM
hartsmike
Oct 2, 2015 07:11 AM
dusterbd
Sep 29, 2015 08:40 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
