why makes this happen?
Old Sep 17, 2002 | 04:21 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
so when im at a stop let off the clutch and the car shakes really bad then once it gets going it stops. it only happens like half the time. anybody have an idea why?
Old Sep 17, 2002 | 04:42 PM
chev-hell's Avatar
usually means the flywheel needs re-surfaced or has hot-spots, or if you have a Hayes clutch it's common , try giving less gas when taking off. somethimes it helps the shake.
Old Sep 18, 2002 | 05:31 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
i don't use the gas when i get off the clutch and it shakes. if i give it gas then the shaking is not as bad. it is possibley my trasmisson mounts could be loose?
Old Sep 19, 2002 | 05:20 AM
kat3876's Avatar
i dont think you are giving enough information here its a little to vague please describe your problem more in detail,,
jhawkeye
May 25, 2022 06:33 PM
xxx3man`
Sep 23, 2015 10:37 PM
mustangman65_79
Sep 1, 2015 03:51 PM
CORV3TT3
Aug 23, 2015 11:26 AM
