ATTN RB83L69: Need your help badly
Old Sep 17, 2002 | 05:50 PM
MotorCityMuscle's Avatar
ATTN RB83L69: Need your help badly...I think I shorted out my whole car
This is a continuation of my post yesterday about my car refusing to crank.
i took your advice and jumped the starter terminals with a remote starter switch, and the car cranked. But then one of the little alligator clips popped off the terminal it was on. So I crawled under the car and replaced it. When I tried to crank the engine again, I got nothing. Now there is absolutely no power in the system. No lights, horn, windows, nothing works now.
Did I short out my entire car?
This has actually happened to me before, and I fixed it by removing and replacing every ground under the hood. i tried that today, but with no luck.
The grounds I undid were:
-1 DS and 1 PS on the radiator support
-Engine to firewall ground strap
-a black one that i believe is part of the HVAC wiring
-black wire from NEG battery cable to fender support
-NEG battery cable to alternator bracket
What should I do to fix the short? Any ideas what may have caused it?
Any help here is really appreciated. Thanks in advance.
Old Sep 17, 2002 | 06:05 PM
1986redbird's Avatar
I know I'm not rb83, but, you may have poped the fusible link that sends power to the whole car, it is down by the starter and is there for that very reason.
Old Sep 17, 2002 | 09:18 PM
Is that the wire from the POS battery cable to the alternator? How do I know if I messed it up?
Old Sep 17, 2002 | 10:10 PM
CamaroDriver's Avatar
I think it's down by the starter. :lala:
Old Sep 18, 2002 | 05:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
OK, I'll help badly....
Most likely, a fusible link is at fault. Probably the clip touched the wrong things at the same time.
The links are a piece of wire, about 14 gauge, that acts like a fuse to protect the high power part of the car's wiring. There are 2 of them: they go from a ring terminal that goes on the large post on the starter along with the battery cable, to the 2 big red wires that carry power to different parts of the car's electrical system. About half of the electrical system is fed by each.
It shouldn't be too hard to figure out which one is bad, it's probably burned in half. Cut it off from the big red wire, splice a new one on with a crimp terminal (or soldering if you can), and put a 3/8" ring terminal on it to hook back up to the starter. You should be able to get the "fusible link wire" at NAPA or the like, I don't know if Auto Zone or CSK or any of those carries it in bulk, or if maybe they have pre-made ones you just splice onto the wire.
So, at least you know now that your starter is good, and your battery is OK, and the batt cable is OK.
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
