GM's BONEHEAD MOVE
Old Sep 17, 2002 | 10:40 PM
FU-Q's Avatar
GM's BONEHEAD MOVE
I hate to be a complainer but i cant help but point out this stupid move of GM. WHY? WHY? WHY? would they make a hatch motor with a moving plastic piece inside? "PLASTIC" AND "MOTOR" DON'T GO TOGETHER!!! can you imagine an 350 with cheap plastic pistons in it? does anyone sell aftermarket Metal gears?
Old Sep 17, 2002 | 11:37 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Yes, but in my opinion, the absolute worst part of the design is the plastic gear housing. This housing absorbs most of the load when a trunk is accidently slammed. The screws that thread themselves into the housing simply break out and the whole motor is now in sloppy contact with the plastic gears.
Old Sep 18, 2002 | 03:44 AM
Enkil's Avatar
The also used plastic for the gears and bearings in the headlight motors for firebirds.
Weight savings! heh
Old Sep 18, 2002 | 06:49 AM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
I can go you one better (not a third gen, well maybe not the eights) on my moms bonneville 3.8 we had an engine coolent line blow appart. Guess why....the connection to the block which was plastic had ripped apart. Can you believe that a part the actually comes in contact with the block is plastic, not only that i carries hot coolent under pressure to the block. Real smooth gm.
Old Sep 18, 2002 | 07:00 AM
Kevin Johnson's Avatar
Isn't someone on the Thirdgen boards making a reinforced kit? Might want to do a search.
Old Sep 19, 2002 | 08:32 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Let me guess was it the one that goes into the front of the manifold? My grandpas cracked and when i went ot fit it i was like WTF? so i cut it out and now GM sells a steel one.
Old Sep 19, 2002 | 11:32 AM
Jokerman's Avatar
Yup. Thats the one. I would love to know what the hell they were smokeing because common sense would say that plastic on a high pressure high heat coolant line going into a metal block would be a not so great idea for longevity (i think the car had about 50,000 miles on it at the time).
Old Sep 19, 2002 | 04:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
my gramps had 51,000 on it.
Old Sep 19, 2002 | 05:01 PM
Jasper89ROC's Avatar
Mine has 73,000 miles on it, no problems here
-Mark
Old Sep 20, 2002 | 09:23 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Re: GM's BONEHEAD MOVE
If you think GM is bad, put a magnet on a mid 90's Ford 4.6l intake manifold and watch it slide right off. They even used plastic timing gears and chains.
I even heard they are using plastic engine parts on Explorer's and Expeditions.
Old Sep 20, 2002 | 09:24 AM
Pukka's Avatar
Edit: magnets don't work on aluminum, just tap your finger on it.
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
gord327
Oct 3, 2015 01:25 PM
Fanatic1074
Oct 2, 2015 03:47 PM
