Changing Oil Pan Gasket
Old Sep 19, 2002 | 04:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I hear of people needing to remove the pan to put the new one in, but counldnt you lower the pan an inch, rip out th eold rubber one and put in the new rubber one? I'm thinking it wouldnt take more then 2 hours. Am I missing something?
Old Sep 19, 2002 | 04:59 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Only problem I see, is if the bolts go thru the gasket, then you would have to take it all the way off. But, I've never changed that gasket before, so I may be wrong.
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
nevermind. I wasnt thinking that you had to go under the oil pump and stuff. no replys needed.
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
MY87LT
Aug 17, 2015 08:43 AM
gwade12
Aug 8, 2015 08:17 AM
