Car wouldn't start all of a sudden fix
Old Sep 20, 2002 | 03:35 PM
Black89Z28's Avatar
Just to help anyone with a starting problem like mine:
A few days ago I had a problem with my '89 Camaro not starting all of a sudden. I had drove it into work with it working great, and then went out to start it to leave and it wouldn't start. I tried several times and the battery and starter were working great. I was close to empty on gas when I came in so I started thinking it was really empty, so after getting a few gallons for the tank, and tried again--no help. I had several people in the parking lot with theories, but I ended up getting a ride home and checking this thirdgen site. I did searches, read, and learned quite a lot. After reading and thinking it was fuel, I was thinking fuel pump, so I would have to check the pressure at the fuel rail (passenger's side of engine), but after further checking I realized I wasn't getting any spark--I took spark plug wire off, screw driver in end of it hold very close to engine while someone cranks engine--no spark. Did same off coil--no spark there. The coil was only a year or so old so I didn't think it was that. Anyway, in the end, it turned out to be the ignition module, and it's not that hard a fix if you know that is it, and you like lying on the engine to work under the distributer cap. Once it was replaced it started right up first time.
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
killer777
Aug 8, 2015 02:47 PM
