need help wiring up my distributor,and coil"accel"
Old Sep 20, 2002 | 03:40 PM
PIMPINPHIL's Avatar
can someone tell me how to wire up my accel coil,and distributor?im not sure of the part number of the distributor,it has a small cap,with 9 plugs,for external coil,3 wires from it,red hot,green tach,and brown ground,the coil has plug wire slot,and positive,and negative connections,do i need to ground out the coil?i mean like actual ground,and then run the ground from distibutor to the coil,or what?thanks alot.
Caspar
Jun 19, 2016 11:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86IROC112
Aug 17, 2015 07:57 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
stalkier
Aug 7, 2015 04:49 AM
