L'il help with timing chain keyway identification?
Old Sep 22, 2002 | 08:31 AM
Damon's Avatar
Just swapped a cam and found the motor had a GM timing chain p/n 3735412 in it which has 3 keyways. Unfortunately, they are marked in symbos, not numbers. Which keyway is Advanced, Straight Up and Retarded? Symbols:
o (and the keyway that is used for this is rounded on the top)
triangle (keyway is pointed on top)
rectangle (keyway is square on top)
It just looks like your run-of-the-mill double roller chain. Even worth keeping? It showed ZERO signs of stretch in the 10,000 miles it was in the motor.
Old Sep 22, 2002 | 08:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
o is straight up.
From there, it should be pretty easy to identify which of the others is advanced and which is retarded.
Old Sep 22, 2002 | 02:45 PM
Damon's Avatar
RB, thanks. My first thought was that "o" was straight up but my local shop said the keyway with the squared off top (the rectangular mark) was "straight up." I did a long "hmmmmmm......." in doubt of that answer.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
