desensitiving Knock Sensor can it be done
Old Sep 23, 2002 | 09:12 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
desensitizing Knock Sensor can it be done
i put a scan tool on and it says I'm getting knock counts of 220-230.My friend says it's my Crane Gold rockers that the sensor is hearing.Is there a way to desensitize the sensor or is there a different sensor to use.It pulls 15 degrees of timing at WOT. thanks
Old Sep 23, 2002 | 09:34 PM
boogie's Avatar
You can remove the knock senser(watch out for the coolant flow) and put 6 to 8 wraps of teflon tape on the threads and reinstall.
Old Sep 24, 2002 | 12:14 AM
L98FORM89's Avatar
Engine: 355 HSR
thanks. do you think that will help that much, I had considered puuting a pipe extension on it , to move it away from the block. Thanks again I'll try it
Old Sep 24, 2002 | 04:54 AM
ede's Avatar
ede
i doubt if your rockers are causing your knock counts, unless you're running the valves wrong when you did the r&r on the rockers. check your base timing, fuel octane. plugs and tune up.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
