timing......
Old Sep 25, 2002 | 09:22 PM
AXMAN's Avatar
timing......
I'll bet this one has come up before but my last post leads me to believe that my recent tune up messed with my timing. So I was just wondering, what do I get the timing set at. I am looking for pure performance, what else? I have a 92 Z28 Convert. with a 5.0 tpi. Other mods would be a 2.5 " pipes with a flowmaster muffler 'n such. Thanks for all your help, it's really appreciated.
~Alex
Old Sep 25, 2002 | 11:36 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Hey, well I got the GM Base 350 crate engine a couple months ago, and in the book that I got from it, it says optimal timing should be 10 degrees at 700 RPM's. I always set it to that, and it works great, granted you have a different engine, but I can't see it being too much of a difference to try setting it at that.
Old Sep 26, 2002 | 08:13 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Hey, I have an 87 TA with a 305 TPI. Ive been told the stock base timing is 6 degrees...whether that is what yours is Im not sure. But Im planning on advancing my timing to get that extra kick on the low end. I hear 10 is the highest before you get detonation. Im planning to go 8ish...maybe 10 if Im feel it will work. Hope that helps.
Justin
Chris's 85z
Carburetors
Sep 12, 2004 03:25 AM
gtpfbod
Jun 26, 2003 12:37 PM
