PCV Valve
Old Sep 27, 2002 | 02:46 PM
shotgun's Avatar
Car: 89rs
PCV Valve
Sorry about this, I have noone I can turn to even for this. Just picked up a new PCV valve for 2 bucks, do I just yank the old one out and plug the new one in? It says to clean the hoses, should I use some gas to clean the gunk out the best I can and then run water through them??
Thanks for the help,
Old Sep 27, 2002 | 02:47 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Hmm, good question, I didn't clean out the hose when I did.
Old Sep 27, 2002 | 03:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A piece of hose is like $.25... probably costs more to clean it than to replace it... and of course, cleaning the hose with solvent won't help it keep from cracking, which is how they fail...
Old Sep 28, 2002 | 08:13 AM
Vader's Avatar
Don't be too surprised if you have some odd problems after replacing the PCV valve. I've had issues with aftermarket (specifically, Fram) replacements that are not properly flow calibrated for the application, causing idle and mixture problems for which the ECM couln't compensate. Spend another whole dollar and get the correct AC/Delco replacement part, or just clean the existing valve.
tyeo098
Nov 30, 2015 06:27 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
