Low batt. voltage at WOT?
Old Sep 28, 2002 | 09:44 PM
Steve10's Avatar
I've just noticed that my battery voltage is dropping to ~11.7 when I'm running through the 1/4 mile WOT. It's normal (~13.2) when cruising. New battery, pretty new alternator, tight belt. Any ideas?
Old Sep 28, 2002 | 09:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Any symptoms?
I'd check to make sure the gauge is reading accurately.
Old Sep 29, 2002 | 08:04 PM
Steve10's Avatar
It's definately low. My scanner is reading low and I just got my wide band O2 unit hooked up, which requires a constant 13V, and it's turning off when I go WOT.
Old Sep 29, 2002 | 08:25 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Maybe the alt is spinning too fast? This happened it my pick up truck. If I revved it up too high the radio would shut off because of loss of power. Just a thought.
junior419
Apr 7, 2025 11:35 AM
eustodp
Sep 20, 2015 05:09 PM
gta_knight
Sep 17, 2015 03:48 PM
Formula_88AE
Sep 3, 2015 01:47 PM
RyanJB
Sep 2, 2015 01:27 PM
