bracket mounting with locking header bolts
Old Sep 29, 2002 | 12:41 AM
PIMPINPHIL's Avatar
hi,
i have locking header bolts,i also have power steering,and the one bracket on the power steering used to bolt off the one bolt from the first header bolt,what has everyone else done to get past this?does the serpentine belt setup bolt the same place?thanks.
Old Sep 29, 2002 | 08:22 AM
ede's Avatar
ede
it's been a long time since i put headers on a thirdgen with PS but if i recall i made a stud from a bolt and made a bushing and used a nut. if the problem is the c clip or e clip, whatever they're called use a regular header bolt, or leave it off. if you're worried about the bolt backing out drill it for safety wire.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
