Low vacuum pressure
Old Sep 29, 2002 | 07:24 AM
Z28DJP1987's Avatar
Low vacuum pressure
What can be done to increase the vacuum presure on a 350 TPI
engine (not stock)?? Engine is stalling with the A/C on and also in slow traffic. Otherwise runs great with the A/C off and no load.
Old Sep 29, 2002 | 07:54 AM
ede's Avatar
ede
vacuum and preasure are two differant things. if your vacuum is low you ought to be looking for a leak. if you have driveability problems you ought to trouble shoot it a little and make sure your tune up is good and that there are no codes stored.
Old Sep 29, 2002 | 08:00 AM
Z28DJP1987's Avatar
No leaks in vaqcuum lines and no codes, engine is tuned. Question was how to increase vacuum presure, I am using a cam with a 110 ls? Thanks
Old Sep 29, 2002 | 08:16 AM
ede's Avatar
ede
oh ok i thought you had a driveability problem. vacuum pump would do it, but that's a pretty drastic move. change in timing or af mixture would change it, but i doubt if it'd be much.
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
mdtoren
Aug 23, 2015 12:52 PM
dcbsracing007
Aug 18, 2015 07:24 AM
mdtoren
Aug 16, 2015 05:45 PM
