Old Sep 29, 2002 | 03:44 PM
1986z28's Avatar
Car: 86 z28, 87 IROC, 88 sc, 93 z28
Engine: LG4, LB9, LO3, LT1
Transmission: 700r4, T5, 700r4, 4L60
Axle/Gears: 3.73, 3.45, 2.73, 3.42
400 sb
http://www.rebuilt-auto-engines.com/...41102207384.ce
What is this engine it said its for a camaro? I always thought 98+ were ls1's and 93-95 were lt1s. What was it in these years or is this not a camaro 350? What would have to be changed to put this in a 3rd gen? What kind of hp #'s did camaros have in these year? Thanks for any help. Sorry i dont know anything on 4th gens
Old Sep 29, 2002 | 09:55 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
It's my understanding that the engines from 93 to 1997 were LT1's and they are not 350's. They are technically 346's or something odd like that. Now they are basically the same however. The bore size is just a bit different. (This is only my understanding and may not be correct.) I know they are rated at 275+ horsepower and about 300+ pounds of torque. However with a few bolt ons or internal mods you can easily get it to 400HP. There is pretty good after market for those engines. Either way it looks like a good buy to me. But I wonder myself what the difficulties would be to install that new engine.
Old Sep 29, 2002 | 10:06 PM
Vader's Avatar
That's a standard design 350 SBC, , not from the SBC-II family. It is a Vortec truck engine, but will fit in a ThirdGen the same as a 305 or 350 that might have bene installed originally. One thing to be aware of is that if it was from a truck, the oil pan may not clear the crossmember. If you got one as a short block, it wouldn't matter, but you might get a useless oil pan if you ordered it complete. The compression ratio is probably around 9:1 depending on the VIN designation. You'd also get a cam of unknown profile, but could specify or supply a cam and springs of your choice for a few bucks more.
Incidentally, you can get the same thing NEW from GM for $2,280, with a warranty: http://www.sdpc2000.com/cart.asp?act...id=120&pid=115
Old Sep 30, 2002 | 07:44 PM
1986z28's Avatar
Thanks for the hepl yall, But one more question; anyone have any idea what hp the 1970 400 sb's. Just curoious. Thanks
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
