what cylinder am i on?
Old Oct 1, 2002 | 10:05 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
hey, i'm about to hook up my new ignition system
i pulled the old distributor/ plugs/ wires a while ago
my timing mark (on the balancer) is just right of the timing indicator tab behind the water pump
my guess is that i am on cylinder #8 right now.............if so where should i set my distributor at, etc.
also whats the stock base timing for an LG4? 8* BTDC?
the engine is a 1987 LG4 305 BTW
Old Oct 1, 2002 | 11:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're either between #1 and #8, or between #6 and #5... not enough info to know which one
Old Oct 1, 2002 | 03:27 PM
ok, true, because for every 2 revolutions of the balancer, the distributor rotates once
so i guess i gotta crank the engine over while holding my finger over a spark plug hole, huh
Old Oct 1, 2002 | 03:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
true dat
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
