sparkplugs,wires,cap and rotor.
Old Oct 2, 2002 | 03:47 PM
Hung Start67's Avatar
guys..doing a tune-up in just a touch..was curious thinking about going with rapid fire plugs l-98..was thinking about going with ac delco cap rotor and wires...yes? no?..all suggestions appreciated..thanks...and goooo BUCS...
Old Oct 2, 2002 | 03:56 PM
rezinn's Avatar
I'd suggest heading over to autozone and picking up a cap and rotor kit for 18 bucks. I think conrad makes it - it has brass terminals and is red(think msd). As for the plugs, I ran those for about a year and they were fine. I don't know if they are worth the extra money over regular plugs, but it's your choice. Normally I'd prefer ac delco parts over others. Shop around for the wires, you can get some decent 8mm ones for a bargain from accel. Again, mostly your preference.
Old Oct 3, 2002 | 01:05 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
i just did a tune up too... i used rapid fires and i like them so far. i also went with the autozone cap and rotor kit...seems to be a good unit. i want to get MSD 8mm wires, and a new MSD coil... the coil is a good thing to replace especially if yours is old. ive been told if you go with one brand, use that same brand for everything. i.e. MSD coil, wires, cap, rotor etc... but the conrad cap and rotor is a good unit, so use your judgement on the rest. good luck with those plugs...they can be fun
justin
Old Oct 3, 2002 | 08:49 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I used an Accel cap and rotor from Kragen, autolite plugs and Jacobs 8.5mm wires from my local speed shop. The cap and rotor were like $18, the plugs were I think $3-4 a piece, and the wires were custom cut for $67.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Winchester1094
Aug 18, 2015 10:23 AM
