help! no gas!!!
Old Oct 3, 2002 | 06:43 PM
mike graycar's Avatar
Car: 88 iroc x 2- 1 T-Top, 1 Vert
Engine: 350 tpi, 305 tpi
Transmission: 700R4-2800 stall, 700R4 stock
help! no gas!!!
left work last night, the car sputtered and died. cranks but wount start. 88 iroc 350 tpi. started with the obvious, fuses. everythink looks good-next, spark+fuel. got spark so i look for gas-nothing in the fuel rail! so now i listen for the pump, nothing. alright, work back to relay. when i turn the ignition on i don't hear the relay closing. i swap relays with the maf relay. no good either. so now i pull both relays out and do a continuity check and ohm out the coils. i reading 58 ohms across the coils. my question is: is there something interupting the current to the coil?
Old Oct 3, 2002 | 09:56 PM
o-k did a search, made up jumper to test the fuel pump. will try that tonight when i get off work. that should at least tell me if it's the pump or get me looking in another direction.....
help me out here guys- i'm driving my roommate's vw bug
Old Oct 5, 2002 | 02:31 PM
o-k, made up a jumper wire and tested the fuel pump. nothing, so now i guess it's time to fork out the big bucks.
hey, this is a great thread! i ask all the questions and then i provide all the answers!!!
Old Oct 5, 2002 | 05:24 PM
question!! will a pump from a 4rth gen interchange with a 3rd gen ????
Old Oct 6, 2002 | 07:04 AM
TPI Monte SS's Avatar
Car: 1988 Monte SS
Engine: ZZ4-cammed TPI 355
Transmission: World-Class T5
The pump should be the same size, I don't think that'll be a problem. Get a new GM if you need one, they're pretty reliable. While you're in there, how's your sending unit?? I've got a brand new one for sale if your fuel gauge is off or you wanna replace while you're in there.
I wound up with a TPI tank sending unit for an F-body by accident when I did my engine swap in the Monte two years ago. Damn dealer sent me the wrong part, but since it was a special order, they wouldn't take it back (swap took too long, and I found out too late it was the wrong piece).
Anyway, it's a complete setup and includes directions, a new screen, foam muffler for the fuel pump, new O-ring for the top of the tank, and some other misc. parts to complete the installation. The part number is 25027221. Hit me offlist at oness2nv@aol.com if you're interested!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
