I found this under the dash of my GTA. What is it?
Old Oct 6, 2002 | 09:58 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
What is it? It's definitely a GM part, nothing aftermarket, and I don't have an alarm. Through the slit in the box I can see a little circuit board inside. And the sticker on the outside says to only open it in a static-free environment, so as not to damage it. Could it be related to my oh-so-moody digital dash that only works when it feels like it?
Attached Thumbnails I found this under the dash of my GTA.  What is it?-dcp03882.jpg
Old Oct 6, 2002 | 10:07 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Oh yea... that's one of them.
You know, one of those things.
It looks like it's got a couple relays?
Maybe try taking pics from different angles?
I dunno..... not much help am I?
AJ
Old Oct 6, 2002 | 10:19 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Here's another shot of it. It doesnt look like it's got relays, I think that's just how it comes apart. I didnt take it apart because of the warning sticker on it.
Attached Thumbnails I found this under the dash of my GTA.  What is it?-dcp03880.jpg
Old Oct 7, 2002 | 01:22 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
i THINK I know what that is, but not 100% sure,
It LOOKS LIKE part (half) of your guage cluster. your dashbord sort of "clicks" into place and thats half of it. Those wires going to it carry voltage or signal for guages. I bet one of the green wires goes to your head temp... if you have a volt tester test the gray / pink wires. If the gray wires carry ground, and the pink wires go 12V+ when your ignition is on, then thats definetelly what it is. I think there should be a blue wire (light blue?) in there too, its your turn signal, if you test it with the your signals ON it should flash 12V+. Do it and find out...
Old Oct 7, 2002 | 07:49 AM
Vader's Avatar
I don't have a Grand Theft Auto, so I really don't know. If you find the GM part number on the device, you should be able to discover its purpose though.
Old Oct 7, 2002 | 10:55 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
do you have a digital dash?
Old Oct 7, 2002 | 12:52 PM
AJ_92RS's Avatar
Hey.......
Attached Thumbnails I found this under the dash of my GTA.  What is it?-thingy.jpg
Old Oct 7, 2002 | 01:13 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
That's the little sticker that says DO NOT OPEN!!! No visible part number anywhere on the box.
Yes I do have a digital dash, and I'm thinking it's related to the dash. I'm HOPING it's related to my dash's little problem with the odometer, and occasional non-functioning gauges. I'll go chase some wires from it later this afternoon.
Ghettobird52
Jul 5, 2024 11:18 PM
gta90
Sep 15, 2015 04:00 PM
bjpotter
Aug 12, 2015 06:06 PM
marcusaw
Aug 10, 2015 08:13 AM
antares57
Aug 6, 2015 07:47 AM
