Pulsing, Bucking, then SES...
Old Oct 9, 2002 | 06:54 AM
MuttandJeff's Avatar
Engine: 5.0 TBI
Transmission: 700R4 Auto
Okay, here's my problem, and my engine is in my sig:
For awhile now I have had a smoking coming from the rear of the engine on the Passenger side. When I took it to our local meet recently I was unable to reproduce this smoking so I never have gotten that issue resolved. Anyway, Sunday (10/6) on a hunch I checked the transmission fluid to see if this was causing the smoking. Well the tranny dipstick read a quart low and looked like it needed changing. I added a quart and headed to autozone to get a tranny filter, gasket, and fluid. Autozone didn't have my tranny filter so I didn't get the fluid changed. I don't know if this has anything to do with whats wrong now, but thought I would note what I have done to it recently.
Well now yesterday I start getting a pulsing of the engine and bucking and jerking of the car after a stop light. Last night on my way home, I make a left turn onto my street and I get the engine pulsing, the bucking and then the SES light came on. After I got on my street and straightened out, the light went away and the engine smoothed out.
Well I got the same thing again this morning at a stop light. The light turned green, i gave it gas and it started bucking and jerking yet again but no SES light.
I don't have a scanner to pull the code that it sprung, but does anyone have a good idea what is going on here?
Old Oct 9, 2002 | 08:10 AM
Engine: 5.0 TBI
Does anyone have any kind of a clue???
Old Oct 9, 2002 | 08:20 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
<img src="http://www.tbichips.com/images/aldlconnector.jpg" width="248" height="71">
Put a paper clip between A and B on your ALDL connector under steering column and get us that code.
Old Oct 9, 2002 | 08:26 AM
Engine: 5.0 TBI
Without a scanner, whats a paper clip going to do? Sorry, but I don't see what is going to happen when I do that.
Old Oct 9, 2002 | 08:34 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Try a search for Vader and paper clip, as he has explained it several times, I just never paid attention. Or if Autozone isnt' too far away they will let you use a tester.
Old Oct 9, 2002 | 08:57 AM
Slade1's Avatar
The quick sum of it is you short pins A and B.
Turn the ignition key to the on position, BUT DO NOT CRANK THE ENGINE. Cranking the engine while the pins are shorted may damage the ECM.
The SES light should start flashing.
The code will be as follows.
Flash..Long Pause..Flash..Short Pause..Flash..Long Pause
This will happen three times, 1 Flash followed by a pause then 2 flashes and pause.
Code 12 will be displayed first, then whatever codes is in the car.
When all the codes are done flashing, code 12 will reappear. The SES will just cycle through all the codes over and over.
Ex. Codes, 12,32,12
Flash Flash..Flash
Flash Flash..Flash
Flash Flash..Flash
Flash..Flash..Flash Flash..Flash
Flash Flash..Flash
Flash Flash..Flash
Flash Flash..Flash
Old Oct 9, 2002 | 09:11 AM
Engine: 5.0 TBI
Thanks Slade, but I took Post *****'s, uhh I mean Mark's advice and searched for Vader's posts on paperclips and found it.
Okay now that I've performed the step, the ecm flashed a 1 and a 2 (12) and then a 3 and 4: 34. That was the only thing that came up, before recycling to the 12 signal.
So according to the codes list 34 reads 2 possibilities as follows:
34: MAP sensor voltage high-pressure high/vacuum low
34: MAF signal high - flow low (EFI/TPI/SFI)
I take it only the first one applies to TBI. So I have a vacuum leak somewhere, correct?
Old Oct 9, 2002 | 11:04 PM
Engine: 5.0 TBI
Bumping this up with an update:
Okay, I pulled the code with the paper clip as my previous post explains and I got the code #34 for MAP sensor low vacuum.
Well, the SES light has not triggered yet, so I was wondering if this was a fluke, or a warning sign that something is on its way out the door.
Oh and on the smoking problem: one side smoking I would just dismiss as a valve cover oil leak, but now it smokes from both sides, again the aft end of the engine. Remember, the engine only smokes after a 30-minute commute, or 30+ minute cruise. Is there anything else it could be? Head gaskets ready to blow/blown? I need to change the tranny fluid first then check for smoking?
Any suggestions guys?
Old Oct 10, 2002 | 06:54 AM
Engine: 5.0 TBI
No one has anything more to add?
Old Oct 14, 2002 | 08:33 AM
Engine: 5.0 TBI
Bumping this up again...
Okay, after pulling the code and getting the 34 code for MAP sensor voltage high/vacuum leak, I have yet to throw the code again, but i have encountered the jerking/bucking of the car several more times. Should I just replace the MAP sensor, or should I really look for a vacuum leak (how?where to start?)???
Just a little more help guys.
Old Oct 14, 2002 | 04:29 PM
squirrelybird's Avatar
i wanna know too....i checked my codes and got straight 12s....buuut the codes lie! something is wrong....i get similar symptoms...been chasing it down for a while, and havnt figured it out yet. im about to replace the MAP sensor and TPS....but if i get no trouble codes, does that mean they are not the problem??? is there any way to check them???
Old Oct 15, 2002 | 09:52 AM
Engine: 5.0 TBI
Hey Mark Shields,
I still need answers to this problem. I got the SES light again this morning. Seems worse on morning COLD starts. Both times the SES light has triggered, its been cold.
Old Oct 15, 2002 | 02:28 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
that happened to me once before on my camaro. it turned out to be a loose clamp on the MAF sensor, and the engine was taking in more air than it thought. sometimes it's the really stupid, overlooked things that don't cost anything to go out and check
Old Oct 15, 2002 | 03:43 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
check and make sure the little plastic/rubber vacuum line going to the MAP sensor isn't broken/torn. that maybe the problem. the lines become brittle and break casuing a vacuum leak. thus leading to your code 34. if not you might just go ahead and replace it if there is no vacuum leak. your ecm is very dependent on correct map sensor readings.
Old Oct 15, 2002 | 06:03 PM
i didnt see any obvious leaks in that tube on mine, but anyways, where do you get one of those???i mean that hard plastic vac. line that goes from the MAP sensor??? do you have to go to the dealer??
Old Oct 15, 2002 | 07:00 PM
Car: 1988 IROC-Z
you can always trace where the plastic vacuum line goes. measure the the length needed and go the the auto parts store. purchase the amount needed and "try" is out. if that solves the problem then the plastic hard line is the problem. if not more than likely the sensor is bad. be sure and check that vacuum exists at the vacuum source for the map sensor.
Old Oct 15, 2002 | 08:38 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
not that this is the only prob here but have u changed the fuel filter or run gumoput eXtra in it?? it might help alitle. I had a sim prob yest and the mechanic couldnt figue it out either. I romped on it and it got better. so I put gumout in and sunoco 94 $1.69 Fing war!@%$#@ anyway much better with the other sugested things I also had a vaccume leak and iI fixed it and it was still sputtwering. now its much better Ill fix the fuel filter after the storm.lol hope it helps good luck
InfernalVortex
Apr 20, 2021 11:31 AM
Hal87
Exterior Parts Wanted
Nov 8, 2015 03:40 PM
BrianI
Oct 3, 2015 12:57 PM
Hal87
Sep 26, 2015 09:26 PM
Damon
Sep 26, 2015 04:29 PM
