383 clearance problems w/ oil pan
Old Oct 9, 2002 | 09:39 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I've got a 383 with a 6" rod, Eagle H-beams, a Scat 9000 crank, and I'm having a problem with the rotating assembly contacting the stock oil pan. Is this a common problem? Is the usual fix to simply clearance the baffles out of the pan?
Old Oct 9, 2002 | 09:52 PM
Fast3rdGen's Avatar
yes it is a common problem. the front rod usually hits up in the front of the pan. sometimes you can just "dimple" the pan from the inside out to fix it. i bought a new moroso oil pan when i built mine. it was only $119 and clears up to 3.85 stroke with steel rods.
Old Oct 9, 2002 | 10:38 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
boy i'm glad i found this one....... i'm sorry to hear about the prob dude....
i'm in the middle of a 383 buildup myself and don't need anymore probs either..........
i hope it works out for ya!!!
p.s is that the stock pan used on the 87 up 350's???
Old Oct 9, 2002 | 11:29 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I had the same problem with mine. I just had to do some creative engineering with the hammer. Dimpled the side and had to slightly shave the inside of the pan rail. I've almost got 3,000 miles on the new engine now.....can't wait to take it to the track in a few weeks.
Old Oct 9, 2002 | 11:34 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yep yep. Fixed it with the BFH. Too bad I didnt think to check it before I put the motor in. Ah well, live and learn.
Old May 28, 2004 | 07:07 PM
johnyIROC's Avatar
Dammit.... I just had the exact same problem when I fired my 383 for the first time... I build mine with LT1 rods and it hits the stock oil pan in the front. It's not that big of a deal... but what really pisses me off is that I searched about 10 times on here for that specific issue... and post after post after post morons are saying you can use the stock oil pan with no problems!
From now on... if you don't know WTF you are talking about.. don't answer the questihbons!
Old May 28, 2004 | 08:41 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Every setup is different, some will make it some won't. It's just the luck of the draw i guess.
gta892000
Aug 11, 2019 11:16 AM
mfp189
Sep 27, 2015 09:25 AM
