What can cause the fuel pressure to go down when accelerating?
Old Oct 10, 2002 | 11:23 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
Whats up everyone?
I have a problem with my fuel pressure going down while reving the engine at idle! Any ideas on what would cause this?
njdaewoo
Old Oct 11, 2002 | 02:14 AM
Redliner's Avatar
Car: Tahoe
yeah, the injectors are letting off the built up pressure when you rev your engine
Old Oct 11, 2002 | 02:18 AM
9OFirebirdV6's Avatar
How many PSI is it dropping? In my chilton it says a 8-10psi drop during accelleration is normal. but it could be a weak fuel pump, or dirty fuel filter.
Old Oct 11, 2002 | 08:08 PM
86Tra/maro's Avatar
Its dropping down in the 25-30 lbs range. When it goes down in the 25lbs range the motor starts to run rough. The rough running motor starts at aroung 3000 rpm & continues all the way to redline. I have another post that goes into this further, please read !!
njdaewoo
Old Oct 12, 2002 | 12:18 AM
ir0cflamez's Avatar
sounds like fuel pump. Make sure your gauge isnt to blame first though.
Better not hit WOT for a while
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
