my car just clicks
Old Oct 11, 2002 | 05:12 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
my car just clicks
I just went to start my car and it just clicks down by the starter I think it is the starter but im not positive anyone have a guess? the battery is new and the ignition coil and coil are new.
Old Oct 11, 2002 | 06:15 PM
AT4 T/A at work's Avatar
Well, the click may be your starter solenoid engaging. Try hitting the starter a couple of times with a hammer. I mean just give it a few good taps, don't smash the crap out of it. If it starts after that, you need a new starter.
Old Oct 11, 2002 | 06:19 PM
1987gt's Avatar
Car: 1989 GTA
thanks i know that trick its just that its so hard to get to
Old Oct 11, 2002 | 06:42 PM
SgtSkip's Avatar
Double check your battery terminals. If they're dirty they will cause a lack of current carying capability that looks the same as a bad solenoid.
Old Oct 11, 2002 | 07:00 PM
1987gt's Avatar
Car: 1989 GTA
I checked the terminals and they are in good shape and tight. im under my hood all the time and i keep everything in good shape. imay need to check the cable at the starter end though thanks for the help it is allways appreciated.any other suggestions are welcome.
Old Oct 11, 2002 | 07:03 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I just fixed that problem with my car and it was the starter. The thing that stumped me for a while was that I bought a reman starter and it did the same thing as the original. Traded that one in and that did the trick. Been about 2 weeks now and no problems.
Old Oct 11, 2002 | 11:00 PM
1987gt's Avatar
Car: 1989 GTA
thanks azvolfan i think i have the same problem you had figures it happens when i dont have the money. autozone has a new one for $30.00 lifetime warranty cant beat that.
Old Oct 12, 2002 | 03:34 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Have someone watch your headlights while you start it, if they dim try another battery. A bad alternator can get you home, but not start the car next time. If a dif battery works, it's the alternator, if not....the starter
Old Oct 12, 2002 | 04:04 AM
azvolfan's Avatar
A lifetime starter for $30.00 bucks!!! Wow. I paid $100 at NAPA.
Old Oct 12, 2002 | 09:34 AM
1987gt's Avatar
Car: 1989 GTA
thanks joel but i think the battery is ok the inside light is bright and the power antenna and radio are on but i will check to make sure.
Jae992
Aug 27, 2015 09:07 AM
B_Dubya
Aug 26, 2015 05:09 PM
Linson
Aug 21, 2015 02:12 PM
86Base
Aug 8, 2015 01:34 PM
