My car doesn't like my new coil??!!
Old Oct 12, 2002 | 04:02 PM
Nasty_Bird_'90's Avatar
I just got a new coil for my car, upgrading from the stock one just b/c its original. I replaced it with a coil from PerformanceDistributors.com. Now the car stumbles and misfires at anything over 2k RPM's. WTF?! I played with the timing a little bit, but no help. I advanced it until i heard a little knock, but it did the same thing. So i retarded it some, but of course, that made it worse. Now i'm back where I started, I put the original one back in. What gives?
Old Oct 12, 2002 | 07:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That sort of coil can be real hard on modules...
Get a high-perf module, either from Kelly's heirs or from Accel or MSD.
That's a good coil. I run one too. One of the speed shops in Memphis where I used to live (and where Kelly started Perf Dist, after he worked at Union Auto) carried both MSD and Performance Dist, put a car with the full MSD setup on their dyno, then put a Perf Dist DUI on it; they got about 8 more HP. I don't know why, I wasn't there while they were doing it, but it's something to think about. I knew him, he definitely understood how to make a distributor work.
Old Oct 12, 2002 | 07:50 PM
New ignition module, huh? Which one do you reccomend? I want to be sure I get one that works. Thanks for the info! Did you have the same problem?
Old Oct 12, 2002 | 07:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Perf Dist is a good one; I used to be able to just drive over there at lunch and see Kelly, and buy one while I was there, so it was wasy for me. But like I daid, Accel I know also has aone that will survive, and I think MSD does too. Crane might also.
I murdered a stock module once with one of those coils. I've never had the exact thing you describe happen to me, but I can see how it could. The extra energy they put out isn't free: it has to go in before it comes out. The module has to carry a whole lot more current.
Old Oct 12, 2002 | 08:22 PM
Hey thanx man. I'll give it a shot. If it doesn't work, do you have any other ideas?
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
killer777
Aug 8, 2015 02:47 PM
L98GTA87
Aug 5, 2015 11:02 PM
