View Poll Results: Which heads should I get?
Aluminum L98 Vette heads
11.11%
Iron Sportsman IIs
88.89%
Voters: 9. You may not vote on this poll
Aluminum Vette heads verse Iron Sportsman IIs, which would you get.
Old Oct 12, 2002 | 07:21 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Well , I finally have the money to get some good heads. I might have the chance to get some aluminum vette heads for $400. Thing is, I would need new valve covers or get an adaptor kit, which I assume is another $50 or so. Also, I'd have to have the heads checked out by a shop I take it, so that there adds some money. Porting the heads would add more as well.
Or I could get some Iron Sportsman IIs..
So, which would you get?
or feel free to suggest something else.
Old Oct 12, 2002 | 07:57 PM
Parrydise7's Avatar
GM claims its Fast Burn heads heads are worth 30 hp on a ZZ4.
Old Oct 12, 2002 | 08:03 PM
Car: 99 Formula
Axle/Gears: 342
How much are those heads?
Old Oct 12, 2002 | 08:52 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
sportman IIs! enough said.
Old Oct 12, 2002 | 08:54 PM
Parrydise7's Avatar
A little over $1100.00 at gmpartsdirect.com, including shipping. Check out the description that is included with p/n 12464298 such as a 383 stroker putting out 497 hp. GM claims those heads will flow enough air to support over 500 hp! :hail:
Azrael91966669
25
Jun 20, 2017 04:04 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
