Cam
Old Oct 14, 2002 | 02:20 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Cam
Is it possible to swap cams ion a 3rd gen (firebird) with out completely pulling the motor? I know the radiator would have to come out but will there be enough room to get the cam out and back in? is it possible to undo the motor mounts and tilt the motor enough to get the cam in/out?
Old Oct 14, 2002 | 04:24 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yes...no need to remove the motor mounts.
Old Oct 14, 2002 | 05:28 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
so... just pull the radiator and slide the cam out?
Old Oct 14, 2002 | 06:06 AM
ronterry's Avatar
Car: '94 Corvette
Well, the condensor is in the way also. If you don't have an AC, this shouldn't be a problem. Not sure if you can swing it out of the way without discharging the system if you do.
Ron
Old Oct 14, 2002 | 06:39 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Cool thank you. it has ac that doesn't work so discharging/ completely removing it cause this is my wanna be race car and race cars even wanna be race cars don't have ac cause it adds weight and is useless anyway won't be a problem : ).
Old Oct 14, 2002 | 08:36 AM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
You'll also have to move the radiator cross support bar. I found that just bending it gave enough room for the cam to slide out. This bar is directly in front of the cam (vertical one). Makes life alot easier.
Old Oct 14, 2002 | 08:47 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yup.
Old Oct 14, 2002 | 04:52 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
cool. thanks agian
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
