how can you tell a bad MAP sensor or TPS???
Old Oct 14, 2002 | 04:59 PM
squirrelybird's Avatar
is there any way to know if your MAP sensor or the TPS is bad??? i tried the paper clip in the ALDL, but i only got straight code 12s. i kinda dont wanna drop 50 bones to replace em if one or both are fine.....so how do you test them??????
Old Oct 14, 2002 | 05:12 PM
HawaiiB4C's Avatar
Code 12 is telling you that your computer is working properly and not displaying any trouble codes. If one or both of these sensors is bad it will flag you "service engine soon" light. Do you have any reason to believe one of these is bad?
Old Oct 14, 2002 | 10:59 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
You can test the TPS sensor with a multimeter.
Old Oct 14, 2002 | 11:44 PM
hmmmm i dont have a multimeter.....i wonder if i can borrow one of those from autozone....if so, how EXACTLY do you use it???
oh, hawaii...i have been experiencing awful bucking and jittering of my rpms, and now kinda reving(more like jumping) erraticly. havnt been able to trace a vacuum leak yet, and these sensors funtions seem to the things i have problems with.
guess ill check the codes again.
9192camaro
16
Feb 3, 2019 12:21 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
