running horrible, huge clouds of smoke
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
85 T/A, mods are in sig. the car starts fine (gotta love msd), but it runs horrible. it won't idle unless you hold it above 1500 rpms for 30-45 seconds, then it barely idles at 500 rpms, and it feels like it's trying to shake itself to death. it sounds like its got a HUGE cam because it lopes so much. also, there is a billowing cloud of white smoke with maybe a hint of grey coming out of the exhaust that smells strongly of gas. HELP ME PLEASE
Engine: 4.0
it happened when i bolted on my holley after rebuilding it. could i have messed something up in the carb that would make it run like that?
Car: 4
Engine: 6
Transmission: 5
after rebuilding it
Sounds like you have a pipeline carrying fuel directly from the fuel pump to the intake manifold.
There's your clue. You got something in there wrong. I'd bet you used the wrong power valve gasket: there are 2 styles of gasket, and 2 styles of PV, and they don't mix.
after rebuilding it
Polo Z03
Sep 10, 2015 06:43 PM
