Oil In Air Cleaner
Old Oct 21, 2002 | 10:51 PM
EFF26's Avatar
Car: 1991 firebird
Engine: lo3 305 TBI
Oil In Air Cleaner
For some strange reason I am getting oil in the air cleaner from the rubbr tube that comes up from the vaulve covers. Why is this happening and what can I do to stop or prevent this? Or can I just plug up the hole with an rubber plug?
Old Oct 21, 2002 | 11:59 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
A little oil is normal. You need the breather tube so plugging it isnt a good idea. I would change the breather filter inside the air cleaner and see it it helps, $3. If engough oil gets soaked into the breather eliment overtime it will spew out into the air cleaner.
Old Oct 22, 2002 | 07:22 AM
Vader's Avatar
You might also want to check the PCV valve and its tubing for obstructions. The oil is likely from excess crankcase pressure, caused by a failed PCV system or excessive blowby. Blowby can be from either worn rings, or overloading the engine before it is fully warmed.
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
