Alternator "issues"
Old Oct 22, 2002 | 01:51 PM
89RSOwner's Avatar
Alternator "issues"
Just put a new PS pump and belt on now the alternator stays at about 9-10 volts on highway and goes up to 13v when idling or going very slow. My alternator about to die or si the mew belt just stretching? It is the correct belt and correct PS pump. so thats not it.
Thanks,
David
Old Oct 22, 2002 | 03:27 PM
rezinn's Avatar
What car is this? It takes at least couple hundred miles to stretch a belt, but you can always check the tension to see if it stretched. If you have a voltmeter you can check the voltage at the battery and the alt when the guage reads low. You may find that your guage is innaccurate.
Old Oct 22, 2002 | 05:15 PM
89RSOwner's Avatar
uummm, lol
1989 Camaro
No Voltmeter, just want to know if a fluxuation is normal esp. since the gauge has always been accurate and stayed constantly on 13V/14V before this swap, now it's fluxuating.
-David
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
