86 z motor into my 89 s-10,need help
Old Oct 23, 2002 | 02:25 PM
PIMPINPHIL's Avatar
hi,
i know its not a camaro/firebird,but the motor would be coming out of my 86 z,anyways,i was wondering what kind of setup would you guys reccomend,for my motor,it is a 305,has tpi,but im going to change it to carb,also,im planning on putting in a cam,and all the induction crap,now my question is,what would you guys put on,in the motor?i mean like,i am either going to go with the xe 262,268 cam,im thinking of going with the rpm intake,or weiand stealth,reasong being,i want to swap my motor from my camaro,into my truck later on,after i get my other motor built,and would like to not have to buy another manifold,and all that.so what cam would you guys go with,and intake/carb.
the truck will more than likely stay a 5 speed,and prolly will be driven quite a bit,thanks for your time.
phil
Old Oct 23, 2002 | 02:50 PM
ede's Avatar
ede
since it's a 305 i'll guess because i've never done it or researched it that much. i'd go with a 600 something holley VS on a weiand intake with a lunati brackmaster cam in the .460 range
Old Oct 23, 2002 | 04:29 PM
Marshall89ws6's Avatar
yea if ur cam is gonna b bigger u might wanna get a 650 cfm carb to make sure ur not overcamming and ur getting the right amount of fuel in there...... it shouldnt be too much.
Old Oct 23, 2002 | 09:27 PM
PIMPINPHIL's Avatar
thanks guys for your rec.,does anyone else have any input for me?i was prolly going to switch over my carter 625 cfm carb onto the truck,and buy a 750 cfm,something or other for the camaro,but not sure which kind yet,thanks for your help.
phil
Old Oct 23, 2002 | 09:37 PM
Bort62's Avatar
How bout a 795 CFM quadrajet w/ a performer RPM manifold & Comp XE262H ?
Works for me~
Old Oct 24, 2002 | 12:15 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
what are you running with that bort? also would you recommend changing valve springs since mine have about 80,000 on them??? i was thinking the 262 in my camaro too.
hydrolic144
Sep 8, 2015 06:55 PM
masonta
Sep 1, 2015 06:40 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
