Removing the rear suspension
Old Oct 25, 2002 | 09:41 PM
helloriker's Avatar
Can anyone give me some tips on how to remove the rear suspension safely? I have been caution about the rear springs but I don't know what I should do to do it safely. Please any advice would be most helpful.
Old Oct 26, 2002 | 01:39 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I did it like this using a floor jack and jack stands:
Raise and support car by the rear axle. Disconnect rear shocks.
Place jack stands under sub-frames where the front of the control arms attach.
Slowly lower rear end to the ground. The springs will fall out.
Keep an eye on the brake line so ya don't stretch it. May have to disconnect it.
Old Oct 26, 2002 | 06:04 AM
ede's Avatar
ede
i think i'd just start off with the jack stands supporting the car ,not by the axle instead of moving them like zz said. and you'll find there's a bit more to unbolt if you want to r&r the rear. 2 floor jacks make it a bit more stable to install, or remove, but to remove it'll pretty much fall out on it's own.
Old Oct 26, 2002 | 01:43 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
here's an article on doing a rear swap.
http://www.fl-thirdgen.org/rearswap.htm
Old Oct 28, 2002 | 04:56 PM
helloriker's Avatar
Thanks for the help, I was worried about how much pressure the springs were under. Didn't want them to shoot out and take off a leg or something. Aparantly it is the front end suspension I have to worry about doing that.
Old Oct 28, 2002 | 05:01 PM
mrr23's Avatar
Engine: 360 HSR
yep. the rear falls right out. the front isn't too hard. will be doing some soon on another car. will be taking pics and making another article.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
3rdgenparts
Aug 8, 2015 07:09 PM
