vacuum leak...power brake check valve???
Old Oct 27, 2002 | 01:44 PM
squirrelybird's Avatar
ok.....i finally fixed my missfire (bad wires were finally the culprit). before i suspected a vacuum leak, changed a bunch of soft vac lines, checked EVERYWHERE, changed the check valve behind the intake manifold.
anyways, now with the ignition ok, i am certain i felt a vacuum leak.....i suspect maybe the power brake check valve???
i press brake....rpms droooop....release brake.....rpms suuuurge.
so what you guys think??
Old Oct 27, 2002 | 02:31 PM
breathment's Avatar
hook up a vacum guage!
Old Oct 27, 2002 | 03:26 PM
Benny's Avatar
Could be, I've seen those check valves in the classic industries catalog for about $17.
Old Oct 27, 2002 | 05:19 PM
nawww theyre only like 5 bucks. the ones in classic were probably "correct" for a restoration or something.
breathment...the gauge wont tell me where the leak is???
im gonna replace it for the hell of it, since it is so cheap, just checking to see if anyone knows better
Old Oct 27, 2002 | 05:42 PM
breathment's Avatar
ahh i ment to say a vaccum tester. like one of those hand pump things..
1992 Trans Am
May 10, 2023 07:19 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
