Code 43
Old Oct 29, 2002 | 11:06 PM
Adam62083's Avatar
Code 43
I keep getting a code 43. My car is having slight idle problems. It likes to cut itself off when moving from park to drive or reverse. I cleaned out the IAC.
It idles at 600 in gear, about 800 out of gear. It likes to fluctuate + or- 50-75 rpm. Sometimes it will dip real low, shake, and come back up.
Any Ideas?
Car info -
1992 Formula 350 TPI
L98/700R4
Old Oct 29, 2002 | 11:13 PM
86TATpi's Avatar
Check your TPS to make sure it's adjusted right. Knock sensor signal is also covered by code 43.
Old Oct 31, 2002 | 08:09 AM
Vader's Avatar
Does the idle stop hunting if you bypass the ESC?
Old Oct 31, 2002 | 05:18 PM
Adam62083's Avatar
If you mean unplugging it on the passenger side of the motor, then yes, it stops. Thats when the car is running on mechanical timing right? I have it set at 10*.
Old Oct 31, 2002 | 09:44 PM
Vader's Avatar
Then you likely have an issue with the ESC system, Check the connections, especially at the distributor and detonation (knock) sensor. The sensor itself may be failing or detecting random noise events. You may also have connections issues at the HEI module, so you might want to check there as well, but that is a little less common.
Old Oct 31, 2002 | 11:32 PM
Adam62083's Avatar
Where does it connect at the distributor?
I will probably just replace the knock sensor. Its 10 years old anyways.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
