Dished or flat-top pistons?
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
The last mechanic that "touched" my car 2 years ago changed the original dished pistons for news flat-top (the block, crank, cam, and connecting rods were machined o.k. - the compression was 242 psi per cylinder until the failure). Now I pulled off the aluminum heads (cause is he used no Felpro gasket and bad used bolts and the failure started this year). Question is: I need return to dished pistons before the re-assembly or the flat-top pistons can remains the same?.
Engine: 2.8 V6
Thanks for your comments.
Engine: 2.8 V6
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A cranking compression of 242psi on a compression guage
is too much for pump gas of 93/94 octane.
Probabily whay you had problems.
What problems did you have? detonation?
blown headgaskets, broken ring lands?
You want about 180psi tops on a pump gas motor.
Your compression ratio is prpbabily too high with flat top pistons.
Axle/Gears: No idea
EXACTLY!.
Detonation, at first.
Then I tried with 97 octane gas, then I moved to 101 octane (97 + additive for 4 additional octanes) and no solved the problem.
Then, I retarded the spark timing in 14 degrees reprogramming the EPROM and the detonation finished.
Now, the valves requires new adjustment and the head gasket will be replaced.
(And more $$$$ ).
(And more $$$$ ).
Originally posted by Denis.V
Sorry,
What is water injection?
Sorry,
way to eliminate detonation and preignition
on high compression, supercharged or turbocharged motors.
Allows you to use more compression ratio, boost and or ignition timing while saveing fuel while running a lower octane fuel than normally required.
When the water vapourizes it absorbs a lot of heat which cools
the chamber and fuel/air mix and controls or buffers
the combustion from uncontroled pressure spikes (detonation)
and does a great job of steam cleaning the chambers and tops of the pistons of carbon.
Also saves on fuel that would normally be needed to cool. (fuel dumping)
Axle/Gears: No idea
O.K., thanks,
but how can I inject the fine spray?, with engine running and the car stopped? or at fuel tank?. Only one time or too much times?.
http://www.aquamist.co.uk/
http://www.cnw.com/~redline/waterinjectionkit.htm
http://www.frii.com/~maphill/wi.html
Do a search on the net. There is lot of info on the subject..
www.carrollsupercharging.com
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
