Good idea/bad idea?
Old Nov 1, 2002 | 02:35 PM
Enkil's Avatar
Good idea/bad idea?
I had a thought, and sometimes these can be fairly dangerous, which is why I'm posting this here (and in the electronics board) to get some opinions. It SEEMS fairly harmless, but I don't want to risk burning down my car.
Now, I have a cellphone. Typically, when I'm in my car, it's charging. That being said, I have the bulky charger and wire running through the car. So MY thought is... Go to the store and buy another lighter socket. Splice this into the wires running to the original lighter socket. Then, permanently plug in the charger into the new lighter, hide that behind the radio/ac/stuff, and run the wire into the center console so I can charge the phone in there. That part's simple enough, but here are my questions:
I would like to put a fuse in the line going to the charger. I would simply put an in-line fuse rated the same as the lighter fuse in the fuse panel. But, what about the fuse in the panel? Let's say, for instance, that I use the lighter and the charger at the same time with the factory rating for the fuse in the panel.. Wouldn't that blow the fuse since twice as much current is being drawn? Therefor, in my mind, I would just slap in a fuse rated twice as high as the factory rating, since I'd have two lighter sockets, and then I'd just put another in-line fuse to the original lighter socket with the factory rating. BUT... What else runs off the fuse going to the lighter? If I put in one twice as high at the fuse box, would I have to put an inline fuse in for every piece of equipment ran off that fuse?
And to possibly get around all of that... how hard is it to just run a cable off the battery line that's going into the fusebox?
Old Nov 1, 2002 | 05:30 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
your phone charger is'nt pulling enough amperage to even have this concern, just do it like you planned and you'll have no problems.
Old Nov 1, 2002 | 10:55 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i think the cig lighter is on a 30amp circuit breaker, not a fuse, at least my blazer was like that. anyway, the wires aren't heavy enough gage to support 60 amp, you'd have to rewire it so you dont melt them. but like mentioned, the phone charger won't draw enough current to worry about it.
Old Nov 2, 2002 | 02:53 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I'm pretty sure that you could wire in another cig lighter using any wire that is hot at all times, like your stock cig lighter is, and just make a ground wire for it. If you have an extra spade in your fuse box you could use that. I had a spare in my fusebox that I use for my power seats. That way you can just wire in an inline fuse and not worry about having to change the amprage of the fuse for the original lighter.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
mdtoren
Aug 23, 2015 12:52 PM
Cripley
Aug 17, 2015 03:35 PM
BurlyChev
Aug 16, 2015 09:08 PM
mdtoren
Aug 16, 2015 05:45 PM
