checking fuel pressure
Old Nov 2, 2002 | 02:42 PM
Rocky_IrocZ's Avatar
Am I doing this right. Connect guage to schrader valve, turn key to on position, look at guage for reading. I am getting no needle movement. Thanks
Old Nov 2, 2002 | 03:20 PM
Vader's Avatar
Probably. It's possible the valve core has issues, or the pump is not running. It's easiest to check the pressure with the engine running to verify the regulator operation.
Check to see that the test gauge doesn't have two gaskets or 'O' rings in the connector, and that it is fully seated.
Old Nov 2, 2002 | 05:31 PM
Hung Start67's Avatar
fuel pressure
sounds like you may have a bad gauge..i checked mine with the key in the on position..around 35-40 psi i believe...sounds like its a bad gauge.
92camaroJoe
Jul 29, 2023 07:57 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
pimp2303
Jul 27, 2017 02:03 PM
92camaroJoe
Aug 13, 2015 06:07 AM
