Horsepower Guestimate
Old Nov 4, 2002 | 01:15 AM
Acidtalons's Avatar
Does anyone know approximately how much horsepower a 86 305 (LG) will produce with 9.6:1 compression pistons, World Chevy Torquer 58cc heads, 1.5 roller tip rockers, Hydraulic Roller Lifters w/ Crane Cam, Edelbrock Performer RPM manifold with holley 650 CFM carb?
best guesses and experiences appreciated.
Old Nov 4, 2002 | 03:50 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Need the specs on the cam.
Old Nov 4, 2002 | 10:20 AM
Acidtalons's Avatar
Probably gonna use CRA-119831
Lift
Intake 509
Exhaust 528
Duration
Intake 284
Exhaust 222
Lobe Sepration
112
Old Nov 4, 2002 | 11:15 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Is that maybe supposed to be 214 on the intake, not 284?
If so..... nevermind. I found the specs.
Duration @ .050: 222°/230°
Lobe Separation: 112°
Gross Lift: .509''/.528''
Here's a pick of the graph..... just make sure you're gonna use headers with that cam. It's gonna need them to breath.
AJ
Old Nov 4, 2002 | 01:01 PM
Acidtalons's Avatar
Thanks, by the way, what program are you using?
Old Nov 4, 2002 | 01:42 PM
AJ_92RS's Avatar
Sure. No problem.
It's Desktop Dyno 2000.
It works fairly well for what it's intended for. You have to realize that these are round about estimates for output, and every dyno pull on DD2000 is under "optimum" conditions.
AJ
Old Nov 4, 2002 | 02:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Check your PM's.
Old Nov 4, 2002 | 02:30 PM
Rob116's Avatar
Car: 1986 Z-28 Camaro
Engine: 355
Re: PM's
Hey Mark, if you get a chance, I wouldn't mind a PM while you're at it
Old Nov 4, 2002 | 02:51 PM
Car: 99 Formula
Axle/Gears: 342
Re: Re: PM's
lol. You've got mail...
Old Nov 4, 2002 | 07:13 PM
daverr's Avatar
dyno2000
i cant believe u guys actually use the dyno2000 as basis for engine buildup.i have found that dyno2000 is very inaccurate.
dave
Old Nov 4, 2002 | 07:17 PM
Car: 99 Formula
Axle/Gears: 342
Re: dyno2000
dave
care to elaborate, just wonderin if you've compared it to actual dyno #s . Not , flaming you.
Old Nov 4, 2002 | 07:22 PM
daverr's Avatar
yes i have dyno number proof
my engine that i built which was a small block chevy.i type in all parameters cam specs ,compression etc.dyno2000 said ill make 540 horse.......and the real true engine dyno numbers are 450 hp.
dave
Old Nov 4, 2002 | 07:26 PM
Car: 99 Formula
Axle/Gears: 342
Re: yes i have dyno number proof
dave
Well, was that on an engine dyno or what? I'm sure you know what you're talking about, but I've seen people just not think before.
Cuz, dyno2000 shows flywheel HP,and if you ran the car on a dyno that was RWHP.
Old Nov 4, 2002 | 07:28 PM
daverr's Avatar
engine dyno
it was on the engine dyno..check my other post"just got back from the dyno"
Old Nov 4, 2002 | 07:33 PM
Car: 99 Formula
Axle/Gears: 342
Guess, I'll find out too, when I dyno mine this summer.
Old Nov 4, 2002 | 10:44 PM
AJ_92RS's Avatar
Re: dyno2000
dave
I can't believe u didn't read what I said about DD2000.
AJ
PurelyPMD
May 5, 2016 04:57 PM
dbrochard
Sep 25, 2015 04:56 PM
italiano67
Sep 22, 2015 08:42 AM
formula_novice
Sep 5, 2015 03:58 AM
1LE91
Aug 31, 2015 08:13 PM
